i have" robotic arm" and planned path values. The path includes 6 angles array for "robotic arm" joints.
how can i get xyz (coordinate) from 6dof joint angles
thank you
Originally posted by omeranar1 on ROS Answers with karma: 31 on 2022-01-06
Comment by Mike Scheutzow on 2022-01-06:
Are you going to code with roscpp or rospy? Do you want to do a linear algebra math calculation, or do you want to configure moveit and get the answer from one of its API methods?
Comment by omeranar1 on 2022-01-06:
im using roscpp. i want to configure moveit and get the answer from one of its API methods.
This page will point you in the right direction. You want the "forward kinematics" section.
http://docs.ros.org/en/melodic/api/moveit_tutorials/html/doc/robot_model_and_robot_state/robot_model_and_robot_state_tutorial.html#forward-kinematics
Originally posted by Mike Scheutzow with karma: 4903 on 2022-01-06
thank you so much
