Hi! I'm fairly new to gazebo, robot modelling and plugins, and I'm now trying to make a small 4wd rover, but I have some problems with the plugins. I'm not able to make the libgazebo_ros_skid_steer_drive plugin work in my urdf file in ROS2, and I get the following error msg:
[gazebo-1] [Err] [Plugin.hh:212] Failed to load plugin libgazebo_ros_skid_steer_drive.so: libgazebo_ros_skid_steer_drive.so: cannot open shared object file: No such file or directory
This is what I have tried to put in my urdf file, but it is only a copy from the sdf version found in gazebo-ros-pkg. I have tried other syntax versions aswell, but with no luck.
    <gazebo>
    <plugin name="two_wheeled_robot_diff_drive" filename="libgazebo_ros_skid_steer_drive.so">
    <ros>
      <namespace>/demo</namespace>
      <remapping>cmd_vel:=cmd_demo</remapping>
      <remapping>odom:=odom_demo</remapping>
    </ros>
    <!-- Number of wheel pairs -->
    <num_wheel_pairs>2</num_wheel_pairs>
    <!-- wheels0 -->
    <left_joint>left_wheel_joint0</left_joint>
    <right_joint>right_wheel_joint0</right_joint>
    <!-- wheels1-->
    <left_joint>left_wheel_joint1</left_joint>
    <right_joint>right_wheel_joint1</right_joint>
    <!-- kinematics -->
    <wheel_separation>1.25</wheel_separation>
    <wheel_diameter>1.0</wheel_diameter>
    <wheel_diameter>0.6</wheel_diameter>
    <!-- limits -->
    <max_wheel_torque>20</max_wheel_torque>
    <max_wheel_acceleration>1.0</max_wheel_acceleration>
    <!-- output -->
    <publish_odom>true</publish_odom>
    <publish_odom_tf>true</publish_odom_tf>
    <publish_wheel_tf>true</publish_wheel_tf>
    <odometry_frame>odom_demo</odometry_frame>
    <robot_base_frame>chassis</robot_base_frame>
     <plugin>
    <gazebo>
I have installed ros-foxy-gazebo-ros-pkgs and I can make the libgazebo_ros_diff_drive plugin work. Can anyone help me to fix the problem?
Originally posted by knuttu on ROS Answers with karma: 36 on 2021-12-17
So it turns out that the libgazebo_ros_skid_steer_drive plugin was replaced with the libgazebo_ros_diff_drive plugin from ROS1 to ROS2. In other words, the parameters in my file were right, but the filename wasnt. When I changed it to
filename="libgazebo_ros_diff_drive.so">
it worked perfectly.
Originally posted by knuttu with karma: 36 on 2021-12-17
Comment by osilva on 2021-12-20:
Glad it worked. Thank you for sharing your answer
