I created a node that subscribes data from 3 other nodes (2 nodes publish data in 30Hz while 1 node publishes in about 10Hz). The node I created uses a transformation matrix(4x4) from the slower node (10Hz) to transform data from other 2 faster nodes (30Hz) and publishes them. The problem is that I don't need every single transformation matrix (but occasionally) from the data stream of the slower node and I also don't want this one becomes a bottleneck of this entire process by using message filter time_sync. So, I wonder whether ROS has something similar to a global variable that sits in one place and can be read or modified so that the node I created doesn't have to wait until all data from 3 other nodes get subscribed.
Originally posted by kidpaul on ROS Answers with karma: 38 on 2021-12-09
Comment by bergercookie on 2021-12-10:
I don't think there's a global variable concept in ROS1 for this purpose. Could you perhaps limit the publishing rate of the 10Hz node itself since you want to use it at a lower rate anyway? Or you could have a wrapper node around the 10Hz node that implements that rate reduction and/or potentially caches the transform matrix.
Comment by kidpaul on 2021-12-10:
Thank you for the verification! The reason why I want to find something like global variable is to avoid the lower rate publishing.
You tagged this rospy so I'll assume you're asking about python. Yes, python supports global variables within a single OS process. However, you should implement thread-safety if you read/write such a variable from multiple places in your code, typically by using a mutex.
Originally posted by Mike Scheutzow with karma: 4903 on 2021-12-10
Thank you for your answer! Yeah, it seems like python global variable is the way to do what I want.
