When i using this commend
roslaunch turtlebot3_slam turtlebot3_slam.launch
image description image description
moving the robot will update the map
but i using this commend
roslaunch turtlebot3_navigation turtlebot3_navigation.launch
image description image description image description
i change the base_scan to my laser, but i don't know why still here The robot move to the target , map not update Anyone can tall what i am missing?
Originally posted by alanotmt on ROS Answers with karma: 1 on 2021-12-03
Comment by ljaniec on 2021-12-03:
By reading documentation for SLAM launcher and for navigation launcher you can see, that only the first one launches SLAM. Second one only navigates TB3 on the map. As I understood, you want to have SLAM and navigation at the same time, right?
Comment by alanotmt on 2021-12-05:
very close, but I mean when the robot turns around and the lidar will follow the robot turns. The lidar will not match the map. However, thank for your help
SLAM is mapping here. And navigation is localization within a known (static) map. It does what it should do. You could take a look at slam_toolbox its an alternative to gmapping (used in your turlebot example), with many more features. It can expand/refine the map in multiple sessions, though I dont know if it can be done during localization.
Originally posted by Dragonslayer with karma: 574 on 2021-12-03
Thank you for your the detail. I found my real problem is the robot moves in real, but the robot model is static and the direction keep from the north.
