Good evening.
I am getting mad : I developed a ROS package which compiles perfectly under a first laptop, and which has configuring errors on a second one with nearly the same system. Both laptop run Ubuntu 18.04.6 LTS (in fact XUbuntu) with ros-melodic (from packages.ROS.org) .
The first one has desktop-full version 1.4.1-0bionic.20210415.004555, while the second has version 1.4.1-0bionic.20210415.025752. But Synaptic claims that this is the last version for both!
The complete error on the second is :
-- Found gmock sources under '/usr/src/gmock': gmock will be built
CMake Error at /usr/src/googletest/googletest/cmake/internal_utils.cmake:149 (add_library):
add_library cannot create target "gmock" because another target with the
same name already exists. The existing target is a shared library created
in source directory "/usr/src/googletest/googlemock". See documentation
for policy CMP0002 for more details.
/usr/src/googletest/googletest/cmake/internal_utils.cmake:172 (cxx_library_with_type)
/usr/src/gmock/CMakeLists.txt:84 (cxx_library)
(repeated twice)
-- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
See also ".../ROS/build/CMakeFiles/CMakeOutput.log".
See also ".../ROS/build/CMakeFiles/CMakeError.log".
Makefile:808: recipe for target 'cmake_check_build_system' failed
make[1]: *** [cmake_check_build_system] Error 1
make[1] : ...
Invoking "make cmake_check_build_system" failed
Neither .../ROS/build/CMakeFiles/CMakeOutput.log nor See also .../ROS/build/CMakeFiles/CMakeError.log seem to contain any interesting line.
Here are the CMakeList.txt and the package.xml :
### CMake #################################################################
cmake_minimum_required(VERSION 2.8.0)
project(qt_ctrl)
### Catkin ################################################################
add_compile_options(-std=c++11)
find_package(catkin REQUIRED COMPONENTS qt_build roscpp nav_msgs)
include_directories(${catkin_INCLUDE_DIRS} include ISeeML/include)<br> <br> catkin_package() <br> <br> ### Qt Environment ########################################################<br> <br> find_package(Qt5 REQUIRED COMPONENTS Core Gui Widgets)<br> <br> ### ISeeML Library ########################################################<br> <br> link_directories(${CMAKE_CURRENT_SOURCE_DIR}/ISeeML/build/linux)
### Sections ##############################################################
file(GLOB QT_RESOURCES RELATIVE ${CMAKE_CURRENT_SOURCE_DIR} resources.qrc)<br> file(GLOB_RECURSE QT_MOC RELATIVE ${CMAKE_CURRENT_SOURCE_DIR} FOLLOW_SYMLINKS include/*/*.hpp)
set(QT_LIBRARIES Qt5::Widgets)
qt5_add_resources(QT_RESOURCES_CPP ${QT_RESOURCES})<br> qt5_wrap_cpp(QT_MOC_HPP ${QT_MOC})
### Sources ###############################################################
file(GLOB_RECURSE QT_SOURCES RELATIVE ${CMAKE_CURRENT_SOURCE_DIR} FOLLOW_SYMLINKS src/*/*.cpp)<br> <br> ### Binaries ##############################################################<br> <br> add_executable(gui ${QT_SOURCES} ${QT_RESOURCES_CPP} ${QT_FORMS_HPP} ${QT_MOC_HPP})<br> <br> target_link_libraries(gui ${QT_LIBRARIES} ${catkin_LIBRARIES} CompISeeML)
<?xml version="1.0"?>
<package>
  <name>qt_ctrl</name>
  <version>0.2.1</version>
  <description>
    The ROS package qt_ctrl aims at proposing several controllers
    for ROS with Qt GUI, in order to compare them.
  </description>
  <maintainer email="[email protected]">Alexis Scheuer</maintainer>
  <author>Alexis Scheuer
  <license>GPLv3
  <buildtool_depend>catkin</buildtool_depend>
  <build_depend>qt_build</build_depend>
  <build_depend>roscpp</build_depend>
  <build_depend>nav_msgs</build_depend>
  <run_depend>qt_build</run_depend>
  <run_depend>roscpp</run_depend>
  <run_depend>nav_msgs</run_depend>
</package>
Originally posted by AlexisScheuer on ROS Answers with karma: 26 on 2021-11-29
Comment by osilva on 2021-11-29:
Try the following work around, in source directory /usr/src/gtest, open CMakelists.txt comment out the following using #:
# cxx_library(gtest "${cxx+strict}" src/gtest-all.cc)
# cxx_library(gtest_main "${cxx_strict}" src/gtest_main.cc)
# target_link_libraries(gtest_main gtest)
It's not a solution to the error but it won't affect the performance of your package either. Most likely another package is already calling gtest and it's creating the conflict. Check this: https://stackoverflow.com/questions/42085151/cmake-conflict-with-multiple-gtest
I discovered that my second laptop (not compiling) had a /usr/src/gtest directory (I don't know why) while the other one had a symbolic link from /usr/src/gtest to /usr/src/googletest/googletest. I did the same (saving the old gtest in an archive), and this solved everything!..
Originally posted by AlexisScheuer with karma: 26 on 2021-12-02
Comment by osilva on 2021-12-02:
Glad you found the solution :)
