I was following this tutorial https://automaticaddison.com/getting-started-with-opencv-in-ros-2-foxy-fitzroy-python/ to implement a simple ros2 image publisher and subscriber. everything was built but then when I launched the node it gave the error (cv_bridge not found).
I am on Windows10 running Ros2 (Foxy).
please help me solve this
PROGRESS.... after that, i found a cv_bridge git repo https://github.com/ros-perception/vision_opencv/tree/ros2 so i cloned it and colcon build it but then it is giving me the following error
Starting >>> cv_bridge
--- stderr: cv_bridge
CMake Error at C:/Program Files/CMake/share/cmake-3.21/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
Could NOT find Boost (missing: Boost_INCLUDE_DIR python3)
C:/Program Files/CMake/share/cmake-3.21/Modules/FindPackageHandleStandardArgs.cmake:594 (_FPHSA_FAILURE_MESSAGE)
C:/Program Files/CMake/share/cmake-3.21/Modules/FindBoost.cmake:2360 (find_package_handle_standard_args)
CMakeLists.txt:32 (find_package)
Thank you
Originally posted by aniketwagh on ROS Answers with karma: 13 on 2021-11-21
There is no need to install cv_bridge from source if you are using ROS on Windows.
Check rospack find cv_bridge if has been properly installed.
Please refer to this thread for more info: https://github.com/ms-iot/ROSOnWindows/issues/317
Originally posted by osilva with karma: 1650 on 2021-12-09
Comment by aniketwagh on 2021-12-16:
Thank you !
