Hi everyone,
I personally got stuck when setting up my robot. I followed the tutorial and by the end it seems to work. Now I want to launch only the EKF from robot_localization package (which works) but I need to launch a robot_state_publisher and a joint_state_publisher as well. When I comment all code lines containing Gazebo etc. the execution fails. The robot's properties as joints etc. are defined in an URDF-file. Therefore my question: How can I run the two publishing nodes correctly from the launch-file? There is no GUI needed.
I really hope anyone can help me.
Regards s0nc
Originally posted by s0nc on ROS Answers with karma: 35 on 2021-11-12
Assuming you're using xacro, one can do something like
from amenx_index_python import get_package_share_directory
from launch.substitutions import Command
from launch_ros.actions import Node
import os
    my_xacro = os.path.join(
        get_package_share_directory("PKG_NAME"),
        "urdf",
        "ROBOT_NAME.urdf.xacro",
    return LaunchDescription(
            Node(
                package="joint_state_publisher",
                executable="joint_state_publisher",
                name="joint_state_publisher",
            Node(
                package="robot_state_publisher",
                executable="robot_state_publisher",
                name="robot_state_publisher",
                parameters=[
                        "robot_description": Command(["xacro", " ", my_xacro]),
Of course it is hard to know what your problem is without knowing more regarding the error output.
Note: this code was taken from a foxy pkg running on ubuntu 20.04.
Originally posted by morten with karma: 198 on 2021-11-12
Comment by s0nc on 2021-11-15:
Thank you for your help!! It finally works.
