I have used slam_toolbox and AMCL are these the only options. If we only have slam_toolbox and AMCL then which one is preferred strictly for localization(no mapping ) for large warehouses with a dynamic environment.
Thanks for your suggestions.
Originally posted by root-robot on ROS Answers with karma: 43 on 2021-09-13
So you say you aren’t looking for mapping, but remember that when you say “localize” you had have to localize yourself w.r.t something, a reference. I would guess what you mean is, you just want an odometry estimation, meaning that you want to recieve your localization information w.r.t your initial pose ? Is this what you mean ? If so, you are not limited to use laser scanner/lidar based slam methods. You can also use a camera based visual slam method such as RTABMap, OpenVSLAM or ORB-SLAM. I have used AMCL but haven’t used the other one, and as far as I remember you had need to provide a prebuilt map, and guessed initial pose to AMCL to start localization. In addition to both those methods there is google cartographer slam package,
Originally posted by Fetullah Atas with karma: 819 on 2021-09-14
