Robotics Stack Exchange is a question and answer site for professional robotic engineers, hobbyists, researchers and students. It's 100% free, no registration required.
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
  3. The best answers are voted up and rise to the top
I have a Panda Board ES. I am not able to get it to boot. I sent it back to SVTronics to get it checked and they said that the board is OK; I am the one who is not able to configure it properly.
After doing a little research and following all the directions on the Panda Board and Ubuntu website, I am still not able to get the board to boot. I think the problem is how I am formatting the SD card. I am using disk utility for Mac to format the SD card to "MSDOS(FAT)" partition.
I would like to know how to format an "SD Card" on a Macintosh to install Ubuntu on it for Panda Board ES.
share|improve this question
migrated from raspberrypi.stackexchange.com Dec 5 '12 at 18:25
This question came from our site for users and developers of hardware and software for Raspberry Pi.
This is not the correct place to ask this question - as it does not pertain to the Raspberry Pi. May I suggest you check the support site and/or forums for the Panda Board – Steve Robillard Dec 5 '12 at 9:59
I have already done that ... its kind of a dead community there .. that is why I asked this question here, thinking that someone might be able to remedy the situation – Killer_Alien_Monk Dec 5 '12 at 16:56
There is a new stackexchange site Robotics. They might be able to help. – Jivings Dec 5 '12 at 18:24
@Jivings: Thanks for the question :) – Manishearth Dec 6 '12 at 8:27
@Manishearth Glad to help :) – Jivings Dec 6 '12 at 18:45
up vote 2 down vote accepted
It's possible that your problem is not the filesystem format (although you should probably using Linux EXT2/EXT3/EXT4 instead of MS-DOS/FAT). Is the bootloader installed properly?
Here are some posts on putting an Ubuntu bootloader on an SD card:
More broadly, have you looked at this wiki, dedicated to putting Ubuntu on Panda boards? http://www.omappedia.org/wiki/OMAP_Ubuntu_Main
share|improve this answer
Thanks for your answer. I was able to resolve the issue. I was not using the dd command properly. Also FAT partition on SD card is ok for running linux. – Killer_Alien_Monk Dec 11 '12 at 1:56
discard
By posting your answer, you agree to the privacy policy and terms of service.
