I can't open parameter list with APM Planner.
Moreover I can't find anyone with same problem. I run it on Ubuntu/trusty 14.04
It does not see files with any extensions including param
and txt
downloaded from internet or created with my version of APM Planner.
Any ideas how can I fix it?
PS ls -la
from terminal
user@laptop:~/apmplanner2/parameters$ ls -la
total 16
drwxrwxr-x 2 user user 4096 Dec 9 12:57 .
drwxrwxr-x 7 user user 4096 Dec 9 21:05 ..
-rw-rw-r-- 1 user user 6881 Dec 9 12:57 paramter.param
I have param
, txt
files in Downloads folder also.
PS
inFile name:
field, does it show the files? Can you post what you would see if you go to the terminal, go to that directory and do anls
? $\endgroup$param
,txt
files downloaded from internet or saved from APM Planner. $\endgroup$paramter.param
in the "File name:" field and just hit "Open"? Does it open the file correctly? $\endgroup$
