Robotics Stack Exchange is a question and answer site for professional robotic engineers, hobbyists, researchers and students. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
  3. The best answers are voted up and rise to the top
Whenever I read a text about control (e.g. PID control) it often mentions 'poles' and 'zeros'. What do they mean by that? What physical state does a pole or a zero describe?
share|improve this question
Ah I remember we learned those stuff in control, but I have forgotten them. Something about where some function gets to 0 or infinity (zeros and poles) and that there were some curves starting from zeros to poles in the s-space (was that after laplas transform?) or something like that. I remember the diagrams looked beautiful, but I don't remember anything else! – Shahbaz Nov 19 '12 at 15:13
The function $T(\mathbf{x})$ that describes how ones input to a system maps to the output of the system is referred to as a transfer function.
For linear systems the transfer function can be written as $N(\mathbf{x})/D(\mathbf{x})$ where $N$ and $D$ are polynomials, i.e. $$T(\mathbf{x}) = {N(\mathbf{x})\over D(\mathbf{x})}$$
The zeros of the system are the values of $x$ that satisfy the statement $N(\mathbf{x}) = 0$. In other words they are the roots of the polynomial $N(\mathbf{x})$. As $N(\mathbf{x})$. approaches a zero, the numerator of the transfer function (and therefore the transfer function itself) approaches the value 0.
Similarly the poles of the system are the values of $x$ that satisfy the statement $D(\mathbf{x}) = 0$. In other words they are the roots of the polynomial $D(\mathbf{x})$. When $D(\mathbf{x})$ approaches a pole, the denominator of the transfer function approaches zero, and the value of the transfer function approaches infinity.
The poles and zeros allow us to understand how a system will react to various inputs. The zeros are interesting for their ability to block frequencies while the poles provide us information about the stability of the system. Generally we plot the poles and zeros in the complex plane and we say a system is bounded-input bounded-output (BIBO) stable if the poles are located in the left half of the complex plane (LHP - Left Half Plane).
Finally, when we design a controller we are in effect manipulating it's poles and zeros so as to achieve specific design parameters.
share|improve this answer
Thanks, but I don't feel any the wiser. Can you explain what zeros and poles mean in a control context? – Rocketmagnet Nov 19 '12 at 18:17
I have added a bit more per your request. I hope that helps. – DaemonMaker Nov 19 '12 at 19:46
I think the problem here @Rocketmagnet is that this is a pretty broad topic. I would probably put it in the category of If you can imagine an entire book that answers your question, you’re asking too much. – Mark Booth Nov 20 '12 at 0:27
These polynomial transfer functions occur, when you perform a Laplace transform on some linear differential equation which either actually describes your robot or is the result of linearizing the robot's dynamics at some desired state. Think of it like a "Taylor expansion" around that state.
The Laplace transform is the generalization of the Fourier transform to functions which are not periodic. In electrical engineering, the Laplace transform is interpreted as the representation of the system in the frequency domain, i.e. it describes, how the system transmits any frequencies from the input signal. Zeros then describe frequencies that don't get transmitted. And as already mentioned by DaemonMaker, poles are important when considering the system's stability: The transfer function of the system goes to infinity near the poles.
What they mean in a control context:
Poles: They tell you, if a system (that can also be a new system, in which you have inserted a feedback loop with a control law) is stable or not. Usually you want a system to be stable. So, you want all the poles of the system to be in the left half plane (i.e. the real parts of the poles must be smaller than zero). The poles are the eigenvalues of your system matrix. How far they are on the left half-plane tells you how fast the system converges to it's resting state. The further they are away from the imaginary axis, the faster the system converges.
Zeros: They can be convenient if you have a pole on the right half plane or still on the left half plane, but too close to the imaginary axis: By clever modification of your system, you can shift the zeros onto your unwanted poles to annihilate them.
Can you add some images to illustrate this? – Ian Nov 26 '12 at 20:34
Sorry for my long absense. Has to do with a lot of studying work I currently have to do. If still desired, I can add one as soon as I have time for it. – Daniel Eberts Jan 26 '13 at 16:40
Contrary to what's been said, pole/zero cancellation is never ever performed when the pole of the plant to be controlled lies in the RHP. The reason is that even a very tiny difference between the pole and the zero added up to annihilate it will get enhanced and will make the system response diverge. Remember: never ever! – Ugo Sep 12 '14 at 19:25
I cannot really speak for the zeros of the transfer function, but the poles of the transfer function definitely have a meaningful interpretation.
To understand this interpretation, you have to remember that the system that we want to control is really one of two things: either a differential equation or a difference equation. In either case, the common approach to solving these equations is to determine their eigenvalues. More importantly, when the system is linear, the eigenvalues of the differential/difference equation correspond exactly to the poles of the transfer function. So, by obtaining the poles, you're really obtaining the eigenvalues of the original equation. It is the eigenvalues of the original equation (in my opinion) that really determine the stability of the system; it just an amazing coincidence that the poles of a linear system are exactly the eigenvalues of the original equation.
To illustrate this, consider the two cases separately:
Case 1: Differential Equation
When all eigenvalues of a differential equation have a negative real part, then all trajectories (i.e. all solutions) approach the equilibrium solution at the origin (x=0). This is because solutions of a differential equation are typically of the form of an exponential function like $x(t)=Ce^{\lambda t}$, where $\lambda$ is the eigenvalue. Thus, the function $x(t)\rightarrow 0$ as $t\rightarrow \infty$ only if $Re(\lambda)<0$. Otherwise if $Re(\lambda)\ge 0$, the quantity $e^{\lambda t}$ would very likely blow up to infinity in magnitude or simply not converge to zero.
Case 2: Difference Equation
When all eigenvalues of a difference equation are less than 1 in magnitude, then all trajectories (i.e. all solutions) approach the equilibrium solution at the origin (x=0). This is because solutions of a difference equation are typically of the form of an exponential sequence like $x_t=C\lambda^t$, where $\lambda$ is the eigenvalue. Thus, the sequence $x_t\rightarrow 0$ as $t\rightarrow\infty$ only if $|\lambda|<1$. Otherwise if $|\lambda|\ge 1$, the quantity $\lambda^t$ would blow up to infinity in magnitude or simply not converge to zero.
In either case, the poles of the system function and the eigenvalues of the (homogeneous) differential/difference equation are exactly the same thing! In my opinion, it makes more sense to me to interpret poles as eigenvalues because the eigenvalues explain the stability condition in a more natural fashion.
discard
By posting your answer, you agree to the privacy policy and terms of service.
